I am using Grafana to monitor my own project in kubernetes. I want to send an email notification when an alert is triggered. To do that I have create a configmap which is grafana-config.yaml whose content is like following:
**root@latif:~# cat grafana-config.yaml**
# Source: robomotion/templates/grafana-configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
data:
grafana.ini: |-
[server]
root_url = /api/monitoring
serve_from_sub_path = true
[auth.anonymous]
enabled = true
[auth]
disable_login_form = true
[security]
allow_embedding = true
[smtp]
enabled=true
host=host:port
user=my@emailadress.com
password=**********
from_name=Robomotion Alert Manager
from_address= alert@robomotion.io
When I use kubectl apply -f grafana-config.yaml and restart grafana pod, I can see the mails with the given settings. But in the received mails, there is a specific template to Grafana. I want to edit the template. When I search it, there is an html file for email template in public folder. How can I edit the html file in kubernetes environment and apply the new html file for sending the emails with my edited templates
Thanks…
