Email template personalization
Hi all, I know this is a topic with so many questions… but I didn’t find a solution.
I read some webpage and other information on grafana website… but no way out.
I would like to know where is the HTML template used for de default messages.
I read this post:
https://sbcode.net/grafana/email-alert-template/
after I restart my grafana server but always see same template message
I’m on a docker app with grafana v.9.0.2 (0641b5d0cd).
Thanks ALEN
Hi, I have the same problem that you with the same version of Grafana, after restaring the server always see same template message and not see the customized template message by me. Why?
I have seeing the same documentation about ‘Change Email Alert Template’ of the website sbcode.net
Hi, I solved…
I’m using docker and isn’t into the host… but inside the app.
You have to change “ng_alert_notification.html”.
Try with a backup first… (inside app)
cd /usr/share/grafana/public/emails
mkdir bkp
cp *.* bkp
or you can mount a volume… outside for that file…
- /etc/docker/myfolder/grafana/emails/ng_alert_notification.html:/usr/share/grafana/public/emails/ng_alert_notification.html
Alen
Hi!
Many many thanks for your investigation about this issue.
I modifying the “ng_alert_notification.html” file and solved the problem.
:slight_smile:
Hey guys, can you show your custom ng-alert-notification.html? I used {{.Status}}: {{ .Labels.alertname }} to show my alert name and its status in a table. The {{.Status}} can show the ‘Firing’ string however the {{ .Labels.alertname }} is blank. I am using Grafana v9. Thanks in advance!
Here below… I removed style 'cause is over text limit.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <meta name="viewport" content="width=device-width" />
<body leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" class="main" style="height: 100% !important; width: 100% !important; min-width: 100%; -webkit-text-size-adjust: none; -ms-text-size-adjust: 100%; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; text-align: left; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; margin: 0 auto; padding: 0;" bgcolor="#FFFFFF">
        <table class="body" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: left; height: 100%; width: 100%; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;" bgcolor="#FFFFFF">
                <tr style="vertical-align: top; padding: 0;" align="left">
                        <td class="center" align="center" valign="top" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;">
        <center style="width: 100%; min-width: 580px;">
                                        <table class="row header" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: left; width: 100%; position: relative; margin-top: 25px; margin-bottom: 25px; padding: 0px;">
                                                  <td class="center" align="center" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;" valign="top">
                                                      <table class="container" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: inherit; width: 580px; margin: 0 auto; padding: 0;">
                                                          <td class="wrapper last" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; position: relative; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 10px 0px 0px;" align="left" valign="top">
                                                            <table class="twelve columns" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: left; width: 580px; margin: 0 auto; padding: 0;">
        <td class="twelve sub-columns center" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; min-width: 0px; width: 100%; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0px 10px 10px 0px;" align="center" valign="top">
                              <img class="logo" src="https://cdn.zivost.com/zevops/optimisedImages/grafana.png" style="width: 200px; display: inline; outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; clear: both; border-width: 0;" align="none" />
                            </td>
                            <td class="expander" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; visibility: hidden; width: 0px; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;" align="left" valign="top"></td>
                          </tr>
                                                            </table>
                                                          </td>
                                                        </tr>
                                                      </table>
                                                    </center>
                                                  </td>
                                                </tr>
                                        </table>
                                        <table class="container" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: inherit; width: 580px; margin: 0 auto; padding: 0;" width="600" bgcolor="#efefef">
                                                        <td height="2" class="spacer mb-shorten" style="font-size: 0; line-height: 0; mso-table-lspace: 0pt; mso-table-rspace: 0pt; background-image: linear-gradient(to right, #ffed00 0%, #f26529 75%); height: 2px !important; word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0; border-width: 0;" valign="top" align="left"> </td>
                                                </tr>
                                                        <td class="mini-centered-text" style="color: #343b41; mso-table-lspace: 0pt; mso-table-rspace: 0pt; word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 25px 35px; font: 400 16px/27px 'Helvetica Neue', Helvetica, Arial, sans-serif;" align="center" valign="top">
<div>
{{Subject .Subject "{{.Title}}"}}
{{ define "alert" }}
  {{if ne .ImageURL "" }}
    <td colspan="2" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 24px 0 0;" align="left" valign="top">
       <img src="{{.ImageURL}}" class="fluid-centered" alt="Alerting Panel" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: auto; clear: both; display: block; border: 0;" align="left" />
                </td>
        </tr>
  {{end}}
  {{if ne .EmbeddedImage "" }}
       <img src="cid:{{.EmbeddedImage}}" alt="Alerting Chart Attached Below" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: auto; clear: both; display: block; border: 0;" align="left" />
                </td>
        </tr>
        {{end}}
  {{ if gt (len .Annotations.SortedPairs) 0 }}
        <td colspan="2" class="annotations" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 24px 0 12px;" align="left" valign="top">
          {{ range .Annotations.SortedPairs }}
          <p style="color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0 0 10px; padding: 0;" align="left"><span class="annotations-heading" style="font-weight: bold; text-transform: capitalize;">{{ .Name }}:</span> <span class="annotations-value" style="padding-left: 8px;">{{ .Value }}</span></p>
          {{ end }}
        </td>
      </tr>
  {{ end }}
    <td colspan="2" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;" align="left" valign="top">
      <span class="labels-heading" style="font-size: 14px; font-weight: bold; vertical-align: top; display: inline-block;">Labels:</span>
      <ul class="labels-list" style="font-size: 14px; vertical-align: top; display: inline-block; padding-left: 8px; margin: 0;">
        {{ range .Labels.SortedPairs }}<li>{{ .Name }}: {{ .Value }}</li>{{ end }}
      </ul>
    </td>
  </tr>
    <td colspan="2" class="actions" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 24px 0 12px;" align="left" valign="top">
      {{ if .SilenceURL }}
        <a href="{{ .SilenceURL }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">
          <img alt="" height="14" src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAACXBIWXMAAAsTAAALEwEAmpwYAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAF1SURBVHgBrZLNTsJAEMf/2wYTPfEI9Q1qvBgjsEl5gB498gj1SDHpEKUckaMn4eiNFyAp4cJN30CPHrn5BV1noTWlFD3oJNuZ3Z39zUcH+A9pUffJpzAoOO/xuvvprZHooYCgLISoa7FyFSCbdOXuApj6M43GUVXWhYZUpKP3k1NZ14+kAOYChleVjnssK/ezKHrLAkQuZWIVKCgKyW+n55cUciZClzLoUPOiqISVlPB+s6ZulnNN/ihG3GfT84jKOwGvMO0krVEewoBoHeTA2glIhRuno7WzkH0Yc633sCz/CoiVshdYRGxGKYSo9ahgHnEPoqzvdxP1b/sEHtgsF2e12ditDD6gPE59XgIO8ytfTlbM1DiTzjk7WQvEYgllZ5fSXeE7vnfTOdkC1GqOBSFO2Mk22JG1TB4l+1VzX/IQgQJpBaHHsB6bA47+rNOHUI1O4A/zw2YWAaaT8UyPNkdcZ6JUs0P+7eouGXuO3WC7j7/KF29iokiLUdaFAAAAAElFTkSuQmCC" class="button-img" width="14" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: 14px; clear: both; display: block; height: 14px; vertical-align: sub; margin: 0 5px 0 0; border-style: none; border-width: 0;" align="left" />
          Silence
        </a>
      {{ end }}
      {{ if .Annotations.runbook_url }}
        <a href="{{ .Annotations.runbook_url }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">
          <img class="button-img" alt="" height="14" src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAACXBIWXMAAAsTAAALEwEAmpwYAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAADaSURBVHgBrVNLDoIwFJwq0bjTG+ARvIGeQI/ADdSVARY8oki8jZxEbyDewLUfahttAoEWDM7m9bVvJtN0CrQEyzdENLyjt2RgtoFzjcgl1XTyJw/0T4K8ghmBH8Zz1VhqsaHtVBT7CYwP5KY6tk+xw3k2Kgl0YdmyKrIYvEjB73EqbI+rBC1owMDXGdjws0aqm9MK7Mg7ogE6aInWAqUreLQPanJgdtAgB2YHIgeTuhxUOlBPNcBvKPwFT4RHbnDgLOpNw3EEaxEFblJwIPECZhw8MZAlQkX+C95zCzqWDYrK2AAAAABJRU5ErkJggg==" width="14" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: 14px; clear: both; display: block; height: 14px; vertical-align: sub; margin: 0 5px 0 0; border-style: none; border-width: 0;" align="left" />
          View Runbook
        </a>
      {{ end }}
      {{ if .DashboardURL}}
        <a href="{{ .DashboardURL }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">
          <img alt="" height="14" class="button-img" src="data:image/png;base64,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" width="14" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: 14px; clear: both; display: block; height: 14px; vertical-align: sub; margin: 0 5px 0 0; border-style: none; border-width: 0;" align="left" />
          Go to Dashboard
        </a>
      {{ end }}
      {{ if .PanelURL}}
        <a href="{{ .PanelURL }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">
          <img alt="" class="button-img" height="14" src="data:image/png;base64,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" width="14" style="outline: none !important; text-decoration: none !important; -ms-interpolation-mode: bicubic; width: 14px; clear: both; display: block; height: 14px; vertical-align: sub; margin: 0 5px 0 0; border-style: none; border-width: 0;" align="left" />
            Go to Panel
          </a>
      {{ end }}
      {{ if gt (len .GeneratorURL) 0 }}<a href="{{ .GeneratorURL }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">Source</a>{{ end }}
    </td>
  </tr>
      <div style="height: 24px;"></div>
      <div style="background-color: #c7d0d9; height: 1px;"></div>
    </td>
  </tr>
{{ end }}
{{ if gt (len .Message) 0 }}
 {{ .Message }}
{{ else }}
<table class="row" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: left; width: 100%; position: relative; display: block; padding: 0px;">
    <td class="twelve" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0;" align="left" valign="top">
      <table style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: left; padding: 0;">
          {{ if gt (len .Alerts.Firing) 0 }}
              <td colspan="2" class="section-heading" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #2c3235; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: bold; line-height: 19px; font-size: 22px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0 0 32px;" align="left" valign="top">
                Firing: {{ .Alerts.Firing | len }} alert{{ if gt (len .Alerts.Firing) 1 }}s{{ end }}{{ if gt (len .GroupLabels.SortedPairs) 1 }} for
                {{ range .GroupLabels.SortedPairs }}
                {{ .Name }}={{ .Value }}
                {{ end }}{{ end }}
              </td>
            </tr>
            {{ range .Alerts.Firing }}
                <td class="status-tag status-firing" width="68" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #ffffff; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; width: 68px; margin: 0; padding: 4px 8px;" align="center" bgcolor="#e02f44" valign="top">
                  Firing
                </td>
                <td class="alert-label" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: bold; line-height: 19px; font-size: 16px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; text-decoration: underline; margin: 0; padding: 0 0 0 12px;" align="left" valign="middle">
                </td>
              </tr>
              {{ template "alert" . }}
            {{ end }}
          {{ end }}
          {{ if gt (len .Alerts.Resolved) 0 }}
                Resolved: {{ .Alerts.Resolved | len }} alert{{ if gt (len .Alerts.Resolved) 1 }}s{{ end }}{{ if gt (len .GroupLabels.SortedPairs) 1 }} for
                {{ end }}{{ end }}
              </td>
            </tr>
            {{ range .Alerts.Resolved }}
                <td class="status-tag status-resolved" width="68" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; color: #ffffff; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; width: 68px; margin: 0; padding: 4px 8px;" align="center" bgcolor="#464c54" valign="top">
                  Resolved
                </td>
                </td>
              </tr>
            {{ end }}
          {{ end }}
              <a href="{{ .AlertPageUrl }}" class="button" style="color: #464c54; text-decoration: none; background-color: #f1f5f9; border-radius: 2px; display: inline-block; font-size: 12px; font-weight: bold; margin: 0 10px 0 0; padding: 5px 9px; border: 1px solid #c7d0d9;">Go to alerts page</a>
            </td>
          </tr>
      </table>
    </td>
  </tr>
</table>
{{ end }}
</div>
                                                        </td>
                                                </tr>
                                        </table>
                                        <table class="footer center" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: center; color: #999999; width: 100%; margin: 0 auto; padding: 0;" bgcolor="#FFFFFF">
                                                        <td class="wrapper last" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; position: relative; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 10px 20px 0px 0px;" align="left" valign="top">
        <table class="twelve columns center" style="border-spacing: 0; border-collapse: collapse; vertical-align: top; text-align: center; width: 580px; margin: 0 auto; padding: 0;">
        <td class="twelve" align="center" style="word-break: break-word; -webkit-hyphens: auto; -moz-hyphens: auto; hyphens: auto; border-collapse: collapse !important; width: 100%; color: #222222; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; font-size: 14px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0; padding: 0px 0px 10px;" valign="top">
        <p style="font-size: 12px; color: #999999; font-family: 'Open Sans', 'Helvetica Neue', 'Helvetica', Helvetica, Arial, sans-serif; font-weight: normal; line-height: 19px; -webkit-font-smoothing: antialiased; -webkit-text-size-adjust: none; margin: 0 0 10px; padding: 0;" align="center">
        Sent by <a href="{{.AppUrl}}" style="color: #E67612; text-decoration: none;">Grafana v{{.BuildVersion}}</a>
        <br />© 2022 Grafana Labs
        </p>
        </center>
        </td>
        </tr>
        </table>
                                                        </td>
                                                </tr>
          </table>
                          </center>
                        </td>
                </tr>
</table>
</body>
</html>
Much thanks to you ! :grinning: :grinning:
WHY does Grafana lead people to believe they can format notifications via the AM GUI (Contact Points, templates). In truth, one must ssh to the server, find and edit /usr/share/grafana/public/emails/ng_alert_notification.html. It is a complex, un-commented, 1,300 line ugly mix of CSS and html. This file is not even documented in the official v9.5 documentation. Found it in the 10.0 docs, thanks to Alen’s tip about its existence.
Thanks very much @alencappelletti for sharing the documentation link!
Hey Grafana - documentation is available, not on grafana.com, but, instead, on sbcode.net :astonished: Why not on grafana.com for v9.5? Maddening!
Hi! We really don’t recommend users to directly edit that template. It’s built from an MJML template (with partials) that live here grafana/emails/templates/ng_alert_notification.mjml at main · grafana/grafana · GitHub
It includes some instruction for how you can compile the email templates we use as a source (it includes comments) yourself.
What is the intended way in Grafana to customize the alert notification email template then?
