Thank you very much, I didn’t know about the commenting out of the semicolon.
I removed all the semicolons, but there is no change in the date format
I did restart and reboot.
Got you. Do you still have a line that says “enable = [date_formats]” as in the screenshot? I’m not sure where that came from but it’s not valid. Your config file needs to have a section that looks exactly like what’s in Grafana v7.2 released with custom date formats, new transforms and overrides | Grafana Labs
“enable = [date_formats]” is original grafana.ini file.
Changing it to “[date_formats]” solved it (makes much more sense), thank you !
Hi @lmerro , I also want to change the default date format in the x-axis to yyyy/mm/dd in Grafana version six, but I did not find a solution for this problem.
Did you get any results?
hello all,
has there been any update on this?
Is there an easy way to change the date format to say a european one?
that’d be great!
thank you for the suggestion. I just tried it and it doesn’t work for me. The date style of the panel is still month/date.
Is there any way this change of date presentation can be applied throughout all dashboards?
Finally, thank you
Seem not working with time series because it overalaps ( in my case) with a cast tranform type
