Date in local format
Hi.
I’ve got a couple of graph panels which go over the past week and the past month, showing values on the Y axis and the date on the X axis.
However, the date is shown as mm/dd, which I know some people think makes sense, but it doesn’t to my users (in Europe) - they expect 5/10 to mean the 5th of October, and 5/13 is just silly.
So, how to do I tell Grafana that we want local date representation on the X axis of graphs?
I can’t possibly be the first person to run into this problem…
Thanks,
Antony.
Hi.
X axis of graphs?
Can anyone help with this?
I’d find it hard to believe that the date format is hard-coded in an
application like this.
Even if it’s not a GUI setting, it must be in a config file somewhere?
Searching in grafana.ini for “date” or “format” doesn’t give me anything
helpful :frowning:
I would like to know how to change this too. I would have expected it to use the locale of the browser (or even the server), which apparently it doesn’t.
This plugin has the option to create a custom format
Excellent, thanks. I will give it a go.
This Plugin insn’t working i there an other way?
lg
Please make this happen, in the US they also write MM/DD/YYYY. For european this makes no sense at all. I’m wondering why the are not writing the time with 30/11 for half past 11, or 11:30 (don’t forget to use pm and am!).
