- Which Grafana version and what operating system are you using?
9.2.3 on Win11 home
UK styled date format from sql TIMESTAMP -
From mysql, date and time stored in TIMESTAMP format
SELECT Temp AS 'G/H Temp Now', Added AS 'Time:'
FROM green_house.temperature
ORDER BY Added desc LIMIT 1
What happened?
Results formatted as: YYYY-MM-DD HH:MM:SS -
What I would like to happen, would be to have it formatted as 16:23 25 Dec
Or something similar, essentially drop the YYYY and SS and have month as three alpha.
Month as numeric MM would be acceptable if alpha not possible.
Thank you.
