→ Grafana v12.1.1 (df5de8219b) -
- We have a parent variable which is “UserJourney” and it has following Option Search, account or Product and I want to have many other variables which depending of “userJourney“ variable.
Example Namespace variable which can be a key value variable with value.
search : search_ns1|search_ws1|search_ps1, account : account_ns, product : product_nsAnother variables which are path with value Path:
search : search_path, account : account_path, product : product_pathWe wish to userjourney variable which can be selected by user at the top of the dashboard and variables namespace and path which will be used in all my panel query in my dashboard with a automatic reload when I change env variable value. We are using $namespace variable to fetch value of namespace string based on a infinity data source which is backed by a static inline CSV .
I have followed
https://community.grafana.com/t/grafana-dashboard-variables-depending-a-common-one/142059/4
What happened?
- the promql query with ${Namespace} variable interpolating to “search”(value of userJourney selected) — but expected value is “search_ns1|search_ws1|search_ps1“ .
Strangely , ${Namespace} is properly translated when I Use the same variable in Panel Displayname.
The chained dependent variable should translated to expecte string as specified. -
NA -
NA -
Grafana dashboard variables depending a common one - #4 by dawiddebowski
welcome to forum @abishekraj
So userJourney has what as datasource?
Thanks for your response @yosiasz .
the UserJourney has Stackdriver as Datasource
