v7.5.12 (896df7435d) - What are you trying to achieve?
Use variable inside another variable, aka chained variables - How are you trying to achieve it?
I have a variable which type is query:
{"find": "terms", "field": "geoip.country_name.keyword"}
it’s a list of different countries, and I turned on Include all option for this variable.
Then inside anthoer variable called common which is constant type, I set the value to geoip.country_name.keyword:$country
I want to directly use the common variable in my query
- What happened?
The country variable behavior is different from directly using in query and use in another variable. There are two main problem:
:being translated to\\:- for
alloption the value of$countryis different from directly used in query
the result looks like:
geoip.country_name.keyword\\:{Australia,Austria,Brazil,Bulgaria,Canada,China,Cyprus,Ecuador,France,Georgia,Germany,Greece,Hong Kong}
The expected result:
geoip.country_name.keyword:(\"Australia\" OR \"Austria\" OR \"Brazil\" OR \"Bulgaria\" OR \"Canada\" OR \"China\" OR \"Cyprus\" OR \"Ecuador\" OR \"France\" OR \"Georgia\" OR \"Germany\" OR \"Greece\" OR \"Hong\\ Kong\")
Chained variables work same with it in query
the counrty variable
no error
- Did you follow any online instructions? If so, what is the URL?
no
