CELERY_WORKER_SHUTDOWN_INTERVAL=65m
Being new to Grafana OnCall, I’d like to understand the environment variable for Grafana OnCall
Does it mean the celery pod restarting every 65m?
What is the reason behind?
THANK YOU!
In values.yaml for grafana/oncall helm chart, found comments for worker_shutdown_interval
  ## Restart of the celery workers once in a given interval as an additional precaution to the probes
  ## If this setting is enabled TERM signal will be sent to celery workers
  ## It will lead to warm shutdown (waiting for the tasks to complete) and restart the container
  ## If this setting is set numbers of pod restarts will increase
  ## Comment this line out if you want to remove restarts
  worker_shutdown_interval: "65m"
