I have been using the open source Grafana for a couple of years now on premise on a Ubuntu VM, not in Docker. I’ve trying to install OnCall using this link (hobby mode):
However I get this error:
Grafana and Prometheus are already running locally, but this is how ‘docker ps’ and my ‘docker-compose.yaml’ looks. I’m missing something:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
2438bcb7c144 grafana/oncall "sh -c 'uwsgi --ini …" 6 days ago Up 6 days 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp mydocker_engine_1
ed34f543c51c grafana/oncall "sh -c ./celery_with…" 6 days ago Up 21 minutes mydocker_celery_1
2bd197d1c28c redis:7.0.5 "docker-entrypoint.s…" 2 weeks ago Up 2 weeks (healthy) 6379/tcp mydocker_redis_1
docker-compose.yml file
x-environment: &oncall-environment
DATABASE_TYPE: sqlite3
BROKER_TYPE: redis
BASE_URL: $DOMAIN
SECRET_KEY: $SECRET_KEY
FEATURE_PROMETHEUS_EXPORTER_ENABLED: ${FEATURE_PROMETHEUS_EXPORTER_ENABLED:-false}
PROMETHEUS_EXPORTER_SECRET: ${PROMETHEUS_EXPORTER_SECRET:-}
REDIS_URI: redis://redis:6379/0
DJANGO_SETTINGS_MODULE: settings.hobby
CELERY_WORKER_QUEUE: "default,critical,long,slack,telegram,webhook,retry,celery,grafana"
CELERY_WORKER_CONCURRENCY: "1"
CELERY_WORKER_MAX_TASKS_PER_CHILD: "100"
CELERY_WORKER_SHUTDOWN_INTERVAL: "65m"
CELERY_WORKER_BEAT_ENABLED: "True"
GRAFANA_API_URL: https://grafana.com:3000
services:
engine:
image: grafana/oncall
restart: always
ports:
- "8080:8080"
command: sh -c "uwsgi --ini uwsgi.ini"
environment: *oncall-environment
volumes:
- oncall_data:/var/lib/oncall
depends_on:
oncall_db_migration:
condition: service_completed_successfully
redis:
condition: service_healthy
celery:
restart: always
command: sh -c "./celery_with_exporter.sh"
volumes:
depends_on:
redis:
command: python manage.py migrate --noinput
volumes:
depends_on:
redis:
redis:
image: redis:7.0.5
restart: always
expose:
- 6379
volumes:
- redis_data:/data
deploy:
resources:
limits:
memory: 500m
cpus: "0.5"
healthcheck:
test: ["CMD", "redis-cli", "ping"]
timeout: 5s
interval: 5s
retries: 10
volumes:
# grafana_data:
# prometheus_data:
oncall_data:
redis_data:
I’m wondering if I’m missing the prometheus part, I really don’t know at this point. I’m so close, but now lost to how to fix this.
Here is some other screenshots:
Add the local host address:
Then if I select ‘Open Grafana Oncall’
I quickly see this:
Then I get this
If I choose ‘Open Grafana Oncall’. I get:
Sure I use it on-prem. No reason it won’t work. It’s tough to say what’s going on here without logs but it looks like there’s an issue syncing the users from Grafana → Grafana OnCall. Check that the Service Account is set up and API key working. This would be in Grafana>Users and access> Service Accounts. OnCall periodically syncs users from the main Grafana instance into its own DB.
If I setup from docker-compose, everyting works well.
But if Grafana is configurated with tls the Authentication fails at first on the validation of the cert and I think also on the user sync.
@g0nz0uk in the documentation the url ist http://engine:8080 and is your .env file in the same folder as your compose file?
Hello, this is what I see under the Users and Access. I’ve desperate to get this working.
Could you let me know where the log files are or best ones to get for you please and I’ll post back?
I think that is missing?
Here is my compose file
version: "3.9"
BROKER_TYPE: redis
BASE_URL: $DOMAIN
GRAFANA_API_URL: https://localhost:3000
services:
engine:
restart: always
ports:
- "8080:8080"
volumes:
depends_on:
redis:
celery:
restart: always
volumes:
depends_on:
redis:
volumes:
depends_on:
redis:
redis:
image: redis:7.0.5
restart: always
expose:
- 6379
volumes:
- redis_data:/data
deploy:
resources:
limits:
memory: 500m
cpus: "0.5"
healthcheck:
timeout: 5s
interval: 5s
retries: 10
volumes:
grafana_data:
prometheus_data:
oncall_data:
redis_data:
My config.env.save file
echo "DOMAIN=http://grafana.mydomain.com:8080
# Remove 'with_grafana' below if you want to use existing grafana
# Add 'with_prometheus' below to optionally enable a local prometheus for oncall metrics
COMPOSE_PROFILES=with_grafana,with_prometheus
# to setup an auth token for prometheus exporter metrics:
# PROMETHEUS_EXPORTER_SECRET=my_random_prometheus_secret
# also, make sure to enable the /metrics endpoint:
# FEATURE_PROMETHEUS_EXPORTER_ENABLED=True
SECRET_KEY="LnFUzDkciSHUN4353453c6cAmrGGc" > .env
403 errors in log file
logger=accesscontrol.evaluator t=2024-06-03T20:10:28.56227234+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:28.565884946+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/organization/ status=403 remote_addr=10.1.35.130 time_ms=44 duration=44.89981ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:28.597028081+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/teams/ status=403 remote_addr=10.1.35.130 time_ms=42 duration=42.479988ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:28.6128135+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/user/ status=403 remote_addr=10.1.35.130 time_ms=53 duration=53.197862ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=accesscontrol.evaluator t=2024-06-03T20:10:28.890455303+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=accesscontrol.evaluator t=2024-06-03T20:10:28.922211762+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:28.928911437+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/user/ status=403 remote_addr=10.1.35.130 time_ms=40 duration=40.891471ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:28.955257057+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/alert_receive_channels/integration_options/ status=403 remote_addr=10.1.35.130 time_ms=35 duration=35.059267ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=accesscontrol.evaluator t=2024-06-03T20:10:29.024281067+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:29.05562419+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/features/ status=401 remote_addr=10.1.35.130 time_ms=33 duration=33.27114ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=accesscontrol.evaluator t=2024-06-03T20:10:29.130581624+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=accesscontrol.evaluator t=2024-06-03T20:10:29.154575012+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:29.159604325+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/organization/ status=403 remote_addr=10.1.35.130 time_ms=31 duration=31.025914ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=context userId=11 orgId=1 uname=admin.testuser1 t=2024-06-03T20:10:29.188680669+01:00 level=info msg="Request Completed" method=GET path=/api/plugin-proxy/grafana-oncall-app/api/internal/v1/teams/ status=403 remote_addr=10.1.35.130 time_ms=36 duration=36.160813ms size=44 referer=https://hob.global.com:3000/a/grafana-oncall-app/alert-groups handler=/api/plugin-proxy/:pluginId/* status_source=server
logger=accesscontrol.evaluator t=2024-06-03T20:10:47.88940472+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=accesscontrol.evaluator t=2024-06-03T20:10:59.832446774+01:00 level=debug msg="Matched scope" userscope=plugins:* targetscope=plugins:id:grafana-oncall-app
logger=context userId=0 orgId=2 uname= t=2024-06-03T20:11:05.902047025+01:00 level=debug msg="Received unknown frontend metric" metric=frontend_plugin_preload_grafana-oncall-app_ms```
problem got resolved by adding Grafana userID and password as below in .env file and docker-compose.yaml
[root@ip dock]# more .env
DOMAIN=http://localhost:8080
Remove ‘with_grafana’ below if you want to use existing grafana
Add ‘with_prometheus’ below to optionally enable a local prometheus for oncall metrics
e.g. COMPOSE_PROFILES=with_grafana,with_prometheus
#COMPOSE_PROFILES=
#COMPOSE_PROFILES=with_grafana
SECRET_KEY=glsa_P2RBIFPgcwjikBOabpZHyWp79dm74nkx_54715996
GRAFANA_USER=admin
GRAFANA_PASSWORD=admin@123
#GF_SECURITY_ADMIN_USER: ${GRAFANA_USER:-admin}
#GF_SECURITY_ADMIN_PASSWORD: ${GRAFANA_PASSWORD:-admin@123}
[root@ip dock]#
Docker-compose.yaml as below
BROKER_TYPE: redis
BASE_URL: $DOMAIN
SECRET_KEY: glsa_P2RBIFPgcwjikBOabpZHyWp79dm74nkx_54715996
CELERY_WORKER_QUEUE: “default,critical,long,slack,telegram,webhook,retry,celery,grafana”
CELERY_WORKER_CONCURRENCY: “1”
CELERY_WORKER_MAX_TASKS_PER_CHILD: “100”
CELERY_WORKER_SHUTDOWN_INTERVAL: “65m”
CELERY_WORKER_BEAT_ENABLED: “True”
GRAFANA_API_URL: http://10.131.4.136:3000
GRAFANA_USER: ${GRAFANA_USER:-}
GRAFANA_PASSWORD: ${GRAFANA_PASSWORD:-}
GF_SECURITY_ADMIN_USER: ${GRAFANA_USER:-}
GF_SECURITY_ADMIN_PASSWORD: ${GRAFANA_PASSWORD:-}
services:
engine:
restart: always
ports:
- “8080:8080”
command: sh -c “uwsgi --ini uwsgi.ini”
volumes:
depends_on:
redis:
volumes:
depends_on:
redis:
redis:
image: redis:7.0.5
restart: always
expose:
- 6379
volumes:
- redis_data:/data
deploy:
resources:
limits:
memory: 500m
cpus: “0.5”
healthcheck:
test: [“CMD”, “redis-cli”, “ping”]
timeout: 5s
interval: 5s
retries: 10
volumes:
grafana_data:
prometheus_data:
oncall_data:
redis_data:
[root@ip dock]#
