I am looking to make multiple variables that all react to each other so a user of the dashboard can select any of the variables, and the others will automatically fill in with the corresponding values.
It’s pretty easy to make a variable react to another one. For example:
If you choose an email in the variable “email,” then the variable “User_ID” should auto-fill with the user_id that belongs to the user with that email.
But the part I can’t figure out is how to make it work both ways—so that not only “User_ID” reacts to “email,” but “email” also reacts to “User_ID.”
This might just be impossible, and I know that I could also just do something like:
WHERE email = ${email} OR ' ' AND User_ID = ${User_ID} OR ' '
in my query, but the problem would be if the user is dumb enough to fill in two variables and the data they put in the two variables doesn’t correspond with each other, then the queries in my panels won’t find anything because there is no data where that User_ID and that email correspond
