grafana v7.0.4 -
I have two dropdowns , suppose one has 1,2,3,4,5 and other has A,B,C,D,E . if I select 1 from the drop down the other dropdown shows A, if I select 2 the other shows B.
How can i achieve this ? -
How are you trying to achieve it? I have created one dropdown using variable but don’t know how to do this ?
I have followed one 2 dropdowns - one determines the values the other - Grafana - Grafana Labs Community Forums but not sure how to create table in DB and how to incorporate the DB with the grafana dashboard.
