Grafana version: Grafana v9.4.3 in Ubuntu Server 22.04.2 LTS
Flowcharting plugin: 0.5.0
I have this installation. I need to update the Flowcharting plugin because this version is older, but when I try to update from the plugin’s panel, I receive this error:
If I check the list-versions in the server, then detects new versions:
I download a newest version, and I install correctly, as you can see:
But when I restart Grafana, i can’t see changes. In the plugin’s panel I see the same old version:
¿How I can uninstall a “core plugin”? ¿Is normal that the flowcharting plugin are a “core plugin”?
Regards
Hi @cmartin5
Flowcharting plugin is a community based plugin as descirbe on the plugin page.
I am not sure why the error message say that its a core plugin (probably need to open a GitHub issue) as it should not be.
Try to logout and re-login as an admin user and see if it then shows you the new updated version?
Excuse me for not replying soon, I’ve been out of work.
I use an “admin” user to access to Grafana, at the moment, he is the only user we have.
Regards
GitHub - manojrammurthy/grafanaflowchart have created a plugin using react which is alternate to flowcharting please have a look , it does most of the functionality of the old plugin
