Can't set implementation prometheus for alertmanager in helm chart
    9.3.6
    I’m trying to add alertmanager datasource with prometheus implementation in the helm chart.
    I put this config in the values.yaml
  datasources:
    datasources.yaml:
      datasources:
        - name: Alertmanager
          type: alertmanager
          url: http://prometheus-alertmanager:9093
          access: proxy
          isDefault: false
          jsonData:
            implementation: prometheus
  • What happened?
    The alertmanager datasource was successfully added from the grafana dashboard. But the Implementation was still selected Mimir
    The Implementation should be selected Prometheus
  datasources:
    datasources.yaml:
      datasources:
          type: alertmanager
          access: proxy
          isDefault: false
          jsonData:
I noticed this happening as well. I added the apiVersion value to the top and that seemed to fix it.
apiVersion: 1
datasources:
