Can't run the imported dashboard
I have file.json and I wanna import to the dashboard but the items look like empty and cannot run the dashboard why?
“id”: 1,
“title”: “Docker Monitoring”,
“originalTitle”: “Docker Monitoring”,
“tags”: ,
“style”: “dark”,
“timezone”: “browser”,
“editable”: true,
“hideControls”: false,
“sharedCrosshair”: false,
“rows”: [
“collapse”: false,
“editable”: true,
“height”: “250px”,
“panels”: [
“aliasColors”: {
“FS Limit”: “#F9934E”,
“FS Usage”: “#E0F9D7”
“bars”: false,
“datasource”: “influxdb”,
“editable”: true,
“error”: false,
“fill”: 1,
“grid”: {
“leftLogBase”: 1,
“leftMax”: null,
“leftMin”: null,
“rightLogBase”: 1,
“rightMax”: null,
“rightMin”: null,
“threshold1”: null,
“threshold1Color”: “rgba(216, 200, 27, 0.27)”,
“threshold2”: null,
“threshold2Color”: “rgba(234, 112, 112, 0.22)”
“id”: 4,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 2,
“links”: ,
“nullPointMode”: “connected”,
“percentage”: false,
“pointradius”: 5,
“points”: false,
“renderer”: “flot”,
“seriesOverrides”: ,
“span”: 6,
“stack”: false,
“steppedLine”: false,
“targets”: [
“alias”: “FS Limit”,
“column”: “fs_limit”,
“function”: “mean”,
“query”: “select mean(fs_limit) from "stats" where $timeFilter group by time($interval) order asc”,
“series”: “stats”
“alias”: “FS Usage”,
“column”: “fs_usage”,
“function”: “mean”,
“query”: “select mean(fs_usage) from "stats" where $timeFilter group by time($interval) order asc”,
“series”: “stats”,
“target”: “”
“timeFrom”: null,
“timeShift”: null,
“title”: “Filesystem Limit / Usage”,
“tooltip”: {
“shared”: true,
“value_type”: “cumulative”
“type”: “graph”,
“x-axis”: true,
“y-axis”: true,
“y_formats”: [
“bits”,
“short”
“aliasColors”: {},
“bars”: false,
“decimals”: null,
“editable”: true,
“error”: false,
“fill”: 1,
“grid”: {
“leftLogBase”: 1,
“leftMax”: null,
“leftMin”: null,
“rightLogBase”: 1,
“rightMax”: null,
“rightMin”: null,
“threshold1”: null,
“threshold2”: null,
“id”: 1,
“interval”: “”,
“leftYAxisLabel”: “CPU time/sec”,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 2,
“links”: ,
“nullPointMode”: “null”,
“pointradius”: 5,
“points”: false,
“renderer”: “flot”,
“span”: 6,
“stack”: false,
“steppedLine”: true,
“targets”: [
“alias”: “”,
“column”: “cpu_cumulative_usage”,
“function”: “derivative”,
“groupby_field”: “container_name”,
“query”: “select container_name, median(cpu_cumulative_usage) from "stats" where $timeFilter group by time($interval), container_name order asc”,
“series”: “stats”,
“interval”: “2s”
“timeFrom”: null,
“timeShift”: null,
“title”: “CPU Usage”,
“tooltip”: {
“shared”: true,
“type”: “graph”,
“x-axis”: true,
“y-axis”: true,
“y_formats”: [
“ns”,
“short”
“title”: “Row”
“collapse”: false,
“editable”: true,
“height”: “250px”,
“panels”: [
“aliasColors”: {},
“bars”: false,
“decimals”: null,
“editable”: true,
“error”: false,
“fill”: 1,
“grid”: {
“leftLogBase”: 1,
“leftMax”: null,
“leftMin”: null,
“rightLogBase”: 1,
“rightMax”: null,
“rightMin”: null,
“threshold1”: null,
“threshold2”: null,
“id”: 2,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 2,
“links”: ,
“pointradius”: 5,
“points”: false,
“renderer”: “flot”,
“rightYAxisLabel”: “”,
“span”: 6,
“stack”: false,
“targets”: [
“alias”: “”,
“column”: “memory_usage”,
“function”: “mean”,
“query”: “select container_name, mean(memory_usage) from "stats" where $timeFilter group by time($interval), container_name order asc”,
“series”: “stats”
“timeFrom”: null,
“timeShift”: null,
“title”: “Memory Usage”,
“tooltip”: {
“shared”: true,
“type”: “graph”,
“x-axis”: true,
“y-axis”: true,
“y_formats”: [
“bytes”,
“short”
“aliasColors”: {
“TX”: “#890F02”
“bars”: false,
“editable”: true,
“error”: false,
“fill”: 1,
“grid”: {
“leftLogBase”: 1,
“leftMax”: null,
“leftMin”: null,
“rightLogBase”: 1,
“rightMax”: null,
“rightMin”: null,
“threshold1”: null,
“threshold2”: null,
“id”: 3,
“legend”: {
“avg”: false,
“current”: false,
“max”: false,
“min”: false,
“show”: true,
“total”: false,
“values”: false
“lines”: true,
“linewidth”: 2,
“links”: ,
“pointradius”: 5,
“points”: false,
“renderer”: “flot”,
“span”: 6,
“stack”: false,
“targets”: [
“alias”: “TX”,
“column”: “tx_bytes”,
“function”: “last”,
“query”: “select last(tx_bytes) from "stats" where $timeFilter group by time($interval) order asc”,
“series”: “stats”
“alias”: “RX”,
“column”: “rx_bytes”,
“function”: “last”,
“query”: “select last(rx_bytes) from "stats" where $timeFilter group by time($interval) order asc”,
“series”: “stats”,
“target”: “”
“timeFrom”: null,
“timeShift”: null,
“title”: “Network Traffic”,
“tooltip”: {
“shared”: true,
“type”: “graph”,
“x-axis”: true,
“y-axis”: true,
“y_formats”: [
“Bps”,
“Bps”
“title”: “New row”
“nav”: [
“collapse”: false,
“enable”: true,
“notice”: false,
“now”: true,
“refresh_intervals”: [
“5s”,
“10s”,
“30s”,
“1m”,
“5m”,
“15m”,
“30m”,
“1h”,
“2h”,
“1d”
“status”: “Stable”,
“time_options”: [
“5m”,
“15m”,
“1h”,
“6h”,
“12h”,
“24h”,
“2d”,
“7d”,
“30d”
“type”: “timepicker”
“time”: {
“from”: “now-6h”,
“to”: “now”
“templating”: {
“list”:
“annotations”: {
“list”:
“refresh”: false,
“schemaVersion”: 6,
“version”: 12
I’m using grafana:latest
It appears when I try to add the measurement!
