Home Assistant Add-On, Grafana Version 11.6.9 - What are you trying to achieve?
I am trying to use the Operato Windrose plugin for my wind data (collected by Home Assistant and saved in InfluxDB) - How are you trying to achieve it?
I currently have the following two queries:
SELECT mean("value") FROM "km/h" WHERE ("entity_id"::tag = 'gw1100a_wind_gust') AND $timeFilter GROUP BY time($__interval) fill(null)
and
SELECT mean("value") FROM "°" WHERE ("entity_id"::tag = 'gw1100a_wind_direction') AND $timeFilter GROUP BY time($__interval) fill(null)
But I don’t know how to get both into one frame with the correct variable names like in the instructions here…
What happened?
It did not work (Screenshot attached)
It should have displayed the data -
"id": 3,
"type": "operato-windrose-panel",
"title": "Panel Title",
"gridPos": {
"x": 0,
"y": 0,
"h": 8,
"w": 12
"fieldConfig": {
"defaults": {},
"overrides": []
"transformations": [],
"pluginVersion": "1.2.0",
"targets": [
"refId": "A",
"policy": "default",
"resultFormat": "time_series",
"orderByTime": "ASC",
"tags": [
"key": "entity_id::tag",
"value": "gw1100a_wind_direction",
"operator": "="
"groupBy": [
"type": "time",
"params": [
"$__interval"
"type": "fill",
"params": [
"null"
"select": [
"type": "field",
"params": [
"value"
"type": "mean",
"params": []
"measurement": "°",
"alias": "direction",
"query": "SELECT mean(\"value\") FROM \"°\" WHERE (\"entity_id\"::tag = 'gw1100a_wind_direction') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"refId": "B",
"tags": [
"value": "gw1100a_wind_gust",
"operator": "="
"groupBy": [
"type": "time",
"params": [
"$__interval"
"type": "fill",
"params": [
"null"
"select": [
"type": "field",
"params": [
"value"
"type": "mean",
"params": []
"measurement": "km/h",
"hide": false,
"datasource": {
"uid": "eejn8ecji1rlsd",
"type": "influxdb"
"alias": "speed",
"query": "SELECT mean(\"value\") FROM \"km/h\" WHERE (\"entity_id\"::tag = 'gw1100a_wind_gust') AND $timeFilter GROUP BY time($__interval) fill(null)",
"rawQuery": true
"datasource": {
"type": "influxdb"
"options": {
"colorPalette": "default",
"petalsPer90Deg": 4,
"speedBucketsCount": 8,
"speedBucketsSizeAuto": true,
"speedBucketsSize": 2,
"tooltipDecimalPlaces": 1,
"windSpeedUnit": "ms",
"windroseLabels": "compass",
"cardinalLabels": "cardinal",
"showLegend": true,
"doesLegendOverlay": false,
"legendPosition": "right",
"legendAnchor": "bottom"
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
There are no errors - Did you follow any online instructions? If so, what is the URL?
Operato Windrose plugin for Grafana | Grafana Labs
However, I don’t know how to get one frame with wind_speed and wind_direction variables but I currently have two frames and don’t know how to set variable names
