docker-compose.yml
services:
pyroscope:
hostname: pyroscope
container_name: pyroscope
image: "pyroscope/pyroscope:latest"
deploy:
restart_policy:
condition: on-failure
ports:
- "4040:4040"
command: "server"
volumes:
- pyroscope_data:/var/lib/pyroscope
grafana:
hostname: grafana
container_name: grafana
image: grafana/grafana:latest
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_DISABLE_LOGIN_FORM=true
- GF_FEATURE_TOGGLES_ENABLE=traceqlEditor metricsSummary
ports:
- "3000:3000"
volumes:
pyroscope_data:
pyroscope 4040 ok
try add pyroscope in grafana
http://pyroscope:4040
show: unimplemented: 404 Not Found
Ensure that you’re using the correct URL when adding Pyroscope as a datasource in Grafana. The URL should be http://pyroscope:4040, but make sure the DNS resolution works from Grafana container to the Pyroscope container. This might not work if the Grafana container cannot resolve pyroscope as the hostname.
Solution:
- Instead of using
http://pyroscope:4040, try using the full container IP or use localhost or 127.0.0.1 if both Grafana and Pyroscope are in the same container network:
http://localhost:4040
Add a network section to the docker-compose.yml:
version: "3"
services:
pyroscope:
hostname: pyroscope
deploy:
restart_policy:
ports:
- "4040:4040"
command: "server"
volumes:
networks:
- pyroscope_network
grafana:
hostname: grafana
environment:
ports:
- "3000:3000"
networks:
- pyroscope_network
networks:
pyroscope_network:
volumes:
pyroscope_data:
