Hi. I try to integrate grafana phlare(pyroscope) into grafana as datasource.
Currently, all containers are wrapped-up container using docker-compose.
In local machine, it works fine.
pyroscope(phlare) datasource is integrated with grafana well.
But on cloud infrastrucrue, it does not work.
This is my configuration yaml file and docker-compose.yaml file
# grafana datasource configuration
apiVersion: 1
datasources:
- name: Pyroscope
type: phlare
basicAuth: false
editable: true
access: proxy
uid: phlare
url: http://pyroscope:4040
version: 1
jsonData:
minStep: '15s'
backendType: 'pyroscope'
# pyroscope configuration
storage-path: "/var/lib/pyroscope"
retention: 360h # 15 days
exemplars-retention: 72h # 3 days
scrape-configs:
job-name: pyroscope
scrape-interval: 10s
enabled-profiles: [cpu, mem]
# docker-compose.yaml file
version: "3.9"
services:
grafana:
image: grafana/grafana:latest
hostname: "grafana"
container_name: "grafana"
ports:
- "3000:3000"
volumes:
- ./grafana/grafana-datasource.yaml:/etc/grafana/provisioning/datasources/datasources.yaml
environment:
- GF_AUTH_ANONYMOUS_ENABLED=true
- GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
- GF_AUTH_DISABLE_LOGIN_FORM=true
networks:
- pyroscope
pyroscope:
hostname: pyroscope
container_name: pyroscope
image: "pyroscope/pyroscope:latest"
deploy:
restart_policy:
condition: on-failure
ports:
- "4040:4040"
command:
- "server"
volumes:
- ./grafana/pyroscope-local-config.yaml:/etc/pyroscope/server.yaml
networks:
- pyroscope
networks:
pyroscope:
driver: bridge
Cloud infrastructure network configuration.
Running with this configuration and docker-compose.yaml file on local macine. It works well
But when I run at the cloud infrastructure, it does not integrated.
Pyroscope which deployed on cloud infrastrucrue works well.
- This is my question on stackoverflow…
