Can't access Grafana in azure VM
Hi, I created an grafana deployment with the grafana image on azure marketplace. When i try to access the VM with it’s public IP, I get a time out error.
I can access the portal with an other azure VM located on the same subnet then Grafana.
My network security group are configured to let traffic pass on port 3000.
The grafana installation is fresh and the configuration is the default one­.
Any ideas why i can’t access my server from outside the local network ?
Thanks!
Never mind I got the solution. The port 3000 was block by my IT services
