Cannot type the title in two lines in grafana panel
the titles are not properly visible so I am trying to write them in two lines in the Title option:
So far the following doesn’t work
  • Gas to Trailer \n This Month
  • Gas to Trailer \r\n This Month
  • Gas to Trailer <\br> This Month
  • Going to panel’s options> inspect > json and then typing alt+13 (the ascii value for newline) or the unicode value U+000A. This might need further confirmation from others.
(The description of a panel do support newlines, just pressing Enter key gives a newline.)
Any idea how can I make the titles in two lines?
TIA!
Even though it’s been a long time, have you found a solution?
No, unfortunately.
haven’t tried/found anything new
