I am trying to use drag and drop on various dashboard charts to zoom in on the time. This worked on a previous version but on the version I am on now (8.5) this doesn’t work. Not sure if I need to enable that feature or my type of chart (bar chart) does not support drag and drop time selection.
More details below.
Version 8.5 running on Ubuntu. Using UI in Firefox and Chrome, Windows and Ubuntu. -
I want to use my mouse to zoom in on a time series chart. -
I am clicking on a chart and dragging my mouse to try and select a smaller area of time/area of the chart. -
What happened?
Nothing, their is no cursor or border area drawn and when I release the mouse the time selection and chart do not change. -
I expected to see an outline or border drawn over the chart as I drag and on release the charts time and data would update. -
Not sure -
No errors -
No
