Hi I have a problem to display my new Grafana v9.1.5 on my Samsung TV (Tizen browser 3.1.11260) whereas my old instance of Grafana in v8.3.3 work fine.
Does anyone can help me or explain to me if I have any incompatibility ?
Thanks
Thanks
Hi @gregonmac,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![]()
The reason is that Grafana only supports a specific list of browsers which are defined in our Documentation:
Therefore, a suggestion would be to try to install one of the supported browsers on your device, and then it should work (if that does not work, then let us know).
I hope this helps.
