- Grafana: grafana-enterprise-9.0.6-1.x86_64
- OS: Red Hat Enterprise Linux 7.9
- What are you trying to achieve?
Configure alexanderzobnin-zabbix-app.
- How are you trying to achieve it?
Going to plugins/alexanderzobnin-zabbix-app clinking on Enable on Web Console
It’s a server that has no internet access.
- What happened?
It says:
This plugin is not published to grafana.com/plugins and can’t be managed via the catalog.
Ability to configure the datasource with Zabbix plugin with the Web Console in offline mode not just install it.
- Can you copy/paste the configuration(s) that you are having problems with?
I didn’t modified the default configuration. but I have this output con cli:
installed plugins:
alexanderzobnin-zabbix-app @ 4.2.9
Please restart Grafana after installing plugins. Refer to Grafana documentation for instructions if necessary.
Of course I’ve already restarted.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Yeas I did, as I mentioned above. In logs it says:
logger=plugindashboards t=2022-08-04T17:50:25.978979215-03:00 level=info msg="Plugin state changed" pluginId=alexanderzobnin-zabbix-app enabled=true
logger=plugindashboards t=2022-08-04T17:50:25.979078516-03:00 level=info msg="Syncing plugin dashboards to DB" pluginId=alexanderzobnin-zabbix-app
logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=admin t=2022-08-04T17:50:26.71773089-03:00 level=info msg="Request Completed" method=GET path=/api/live/ws status=0 remote_addr=192.168.0.2 time_ms=1 duration=1.976729ms size=0 referer= traceID=00000000000000000000000000000000
logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=admin t=2022-08-04T17:50:26.857844312-03:00 level=error msg="Proxy request failed" err="dial tcp: lookup grafana.com on X.Y.A.B:53: no such host"
logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=admin t=2022-08-04T17:50:26.857948452-03:00 level=error msg="Request Completed" method=GET path=/api/gnet/plugins status=502 remote_addr=192.168.1.2 time_ms=3 duration=3.677231ms size=0 referer="http://192.168.168.45:3000/plugins/alexanderzobnin-zabbix-app?page=config" traceID=00000000000000000000000000000000
logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=admin t=2022-08-04T17:50:26.95496798-03:00 level=error msg="Proxy request failed" err="dial tcp: lookup grafana.com on X.Y.A.B:53: no such host"
logger=context traceID=00000000000000000000000000000000 userId=1 orgId=1 uname=admin t=2022-08-04T17:50:26.955108821-03:00 level=error msg="Request Completed" method=GET path=/api/gnet/plugins/alexanderzobnin-zabbix-app status=502 remote_addr=192.168.0.2 time_ms=3 duration=3.822066ms size=0 referer="http://192.168.168.45:3000/plugins/alexanderzobnin-zabbix-app?page=config" traceID=00000000000000000000000000000000
(For privacy reasons I had to obfuscate some ip address)
- Did you follow any online instructions? If so, what is the URL?
Yes I did: https://alexanderzobnin.github.io/grafana-zabbix/installation/
