I had a table with multiple columns. But I want to show particular column as bar gauge in that table? will that possible if so would anyone please help me?
Thanks in advance
Thanks in advance
The new table panel with Grafana 8 you can display a single value in a cell as a bar gauge. See here for examples.
And see the Grafana demo site table showcase - edit any panel and see/change settings to see the effects. You need to add a “field override” to a table column.
Thanks for your support.
Perferkt. Thanks
