When using any of the “* guage” Cell Display modes, how can I not show the value at the end of the cell. IE: I want the guage itself to take up the entire width of the cell.
What do you mean “the value at the end of the cell”?
Looking at the gauge demo but I’m not sure what you mean:
Could you show a screenshot? Or point out on the screenshot above what you are trying to change?
apologies for not being clear enough.
Using Grafana as an example. On the right side under Sensor where it has the bar graph along with numbers at the end. I’d like to show the cell without the numbers.
Example:
