Hi, I’m using grafana version 5.3.4
I have a field that shows the state of charge, if there is a sudden fall in the data then grafana should alert me. I have attached a graph where there is a drop from 50 to 14 in 8 mins. I can set up the alert rule where grafana can alert me for the threshold values in a given time, but here I want to get an alert whenever there is a fall in the data of 30% in 5 mins(as this fall will happen rarely and I want to make sure I address the Issue, for that, I should be alerted). Is that possible somehow? I would appreciate if anyone helps me with this.
