when I “go run build.go setup”, I got the following errors:
pkg/api/http_server.go:65: undefined: http.ErrServerClosed
pkg/api/http_server.go:71: undefined: http.ErrServerClosed
pkg/api/http_server.go:96: hs.httpSrv.Shutdown undefined (type *http.Server has no field or method Shutdown)
pkg/tsdb/mysql/mysql.go:157: rows.ColumnTypes undefined (type *core.Rows has no field or method ColumnTypes)
pkg/tsdb/mysql/mysql.go:183: undefined: sql.ColumnType
github.com/grafana/grafana/pkg/tsdb/opentsdb
github.com/grafana/grafana/vendor/github.com/prometheus/client_golang/api
github.com/grafana/grafana/vendor/github.com/prometheus/client_golang/api/prometheus/v1
github.com/grafana/grafana/pkg/tsdb/prometheus
exit status 2
exit status 1
does anyone have this issue?
My environment is ubuntu 17.04.
daniel@daniel-X550LD:~/grafana-custom/src/github.com/grafana/grafana$ go run build.go build
Version: 5.3.0-pre1, Linux Version: 5.3.0, Package Iteration: 1531361307pre1
rm -r ./bin/linux-amd64/grafana-server
rm -r ./bin/linux-amd64/grafana-server.md5
go version
go version go1.8.3 linux/amd64
Targeting linux/amd64
go build -ldflags -w -X main.version=5.3.0-pre1 -X main.commit=9b50c9038 -X main.buildstamp=1531333418 -o ./bin/linux-amd64/grafana-server ./pkg/cmd/grafana-server
# github.com/grafana/grafana/vendor/github.com/grafana/grafana-plugin-model/go/datasource
vendor/github.com/grafana/grafana-plugin-model/go/datasource/service.go:20: cannot use GRPCServer literal (type *GRPCServer) as type DatasourcePluginServer in argument to RegisterDatasourcePluginServer:
*GRPCServer does not implement DatasourcePluginServer (wrong type for Query method)
have Query("context".Context, *DatasourceRequest) (*DatasourceResponse, error)
pkg/social/social.go:167: cannot use SocialGrafanaCom literal (type *SocialGrafanaCom) as type SocialConnector in assignment:
*SocialGrafanaCom does not implement SocialConnector (wrong type for Client method)
have Client("github.com/grafana/grafana/vendor/golang.org/x/net/context".Context, *oauth2.Token) *http.Client
want Client("context".Context, *oauth2.Token) *http.Client
exit status 2
exit status 1
and
Version: 5.3.0-pre1, Linux Version: 5.3.0, Package Iteration: 1531361379pre1
go version
# github.com/grafana/grafana/vendor/github.com/grafana/grafana-plugin-model/go/renderer
vendor/github.com/grafana/grafana-plugin-model/go/renderer/service.go:20: cannot use GRPCServer literal (type *GRPCServer) as type RendererServer in argument to RegisterRendererServer:
*GRPCServer does not implement RendererServer (wrong type for Render method)
have Render("context".Context, *RenderRequest) (*RenderResponse, error)
want Render("github.com/grafana/grafana/vendor/golang.org/x/net/context".Context, *RenderRequest) (*RenderResponse, error)
want Query("github.com/grafana/grafana/vendor/golang.org/x/net/context".Context, *DatasourceRequest) (*DatasourceResponse, error)
# github.com/grafana/grafana/pkg/social
pkg/social/social.go:115: cannot use SocialGithub literal (type *SocialGithub) as type SocialConnector in assignment:
*SocialGithub does not implement SocialConnector (wrong type for Client method)
pkg/social/social.go:129: cannot use SocialGoogle literal (type *SocialGoogle) as type SocialConnector in assignment:
*SocialGoogle does not implement SocialConnector (wrong type for Client method)
pkg/social/social.go:144: cannot use SocialGenericOAuth literal (type *SocialGenericOAuth) as type SocialConnector in assignment:
*SocialGenericOAuth does not implement SocialConnector (wrong type for Client method)
exit status 2
exit status 1
