Good Morning,
I’ve been trying to modify Grafana for 3 days and doing a build again.
I have modified the LoginPage to put my company name just below the Grafana logo. But there is no way to recompile the code.
I have a windows and I have followed this tutorial: Installation - Building from source - 《Grafana v6.2 Documentation》 - 书栈网 · BookStack. But when I do: go run build.go setup it gives me this error:
$ go run build.go setup
Version: 8.3.0, Linux Version: 8.3.0, Package Iteration: 1634138282pre
go install -v -buildmode=exe ./pkg/cmd/grafana-server
github.com/grafana/grafana/pkg/login/social
github.com/grafana/grafana/pkg/services/oauthtoken
github.com/grafana/grafana/pkg/tsdb
github.com/grafana/grafana/pkg/api/pluginproxy
github.com/grafana/grafana/pkg/services/ngalert/eval
github.com/grafana/grafana/pkg/services/datasourceproxy
github.com/grafana/grafana/pkg/services/ngalert/state
github.com/grafana/grafana/pkg/services/ngalert/schedule
github.com/grafana/grafana/pkg/services/ngalert/api
github.com/grafana/grafana/pkg/server
github.com/grafana/grafana/pkg/cmd/grafana-server/commands
# github.com/grafana/grafana/pkg/cmd/grafana-server/commands
pkg\cmd\grafana-server\commands\cli.go:168:12: undefined: server.Initialize
exit status 2
exit status 1
are you still hitting this error, @andreuserrasastre
Just checked 8.2.3 hoping that it would have been fixed, but no…
pkg/cmd/grafana-server/commands/cli.go:163:12: undefined: server.Initialize
This issue has not been resolved yet. I am getting the same error while building the application. Could someone help me with this to resolve it or if there is any workaround, that would also be helpful too.
Appreciate the help
see link to GH issue in @atifshoukatali’s post above
How is this working on Windows 10? Everytime i try to run
make gen-go
i get the error: File *.sh not found.
process_begin: CreateProcess(NULL, # Install binary/ries using Go 1.14+ build command. This is using bwplotka/bingo-controlled, separate go module with pinned dependencies., …) failed.
m
Thanks a lot,
Thomas
Hi @andreuserrasastre, I am also facing your error exactly. If your problem is solved, please guide me
Hi @atifshoukatali I want to build Grafana from the source using this link [grafana/developer-guide.md at main · grafana/grafana · GitHub], but I have a problem in the backend build steps in Windows.I have run this command(gen -tags oss ./pkg/server ./pkg/cmd/grafana-cli/runner) in the Wire tool install path, but I am facing this error: ‘gen’ is not recognized as an internal or external command, please help me
please run make gen-go first。
Hello!
I have got the exact same problem
Any idea how to resolve it?
Regards
Hello!
I have used the command that you mention and still the same error ( ‘gen’ is not recognized as an internal or external command).
Regards
