It runs nearly everything good, but yesterday I tried to genereate a package and there I get an error about a file I never touched. After this I release that the command go get GitHub.com/grafana/grafana downloads the newest pre-lease of grafana. But I don’t want to build my grafana on a pre-release. May be the the pre-release version is the reason for the error during the package generation. Is it possible to download with go get the latest stable release of grafana?
But then when I start ‘go run build.go setup’ I receive an error with exit status 2 and exit status 1 with following errors: …adaptor_go1_13:.go:16:14: undefinded: errors.Frame and format_go1_13:go:12:18: undefined: errors.Formatter
go run build.go build fails then with the same error:
