Grafana Version 8.2.0 currently ( Went from 8.1.5 and users hadn’t reported the problem before )
Browser is Edge: 93.0.961.52
Normally I set the columns if I need to show wider data but the suto width works out
When I view from Dashboard at the Panels or in Editor it’s fine like here
But when I View it expands by like 5 pixels a second ( GIF would be better but you get the idea )
Can set manually for all columns so it’s fine but if I try to grab the column in the view to stop it, it shows this error: Cannot read properties of undefined (reading ‘0’)
Can workaround with manually setting column widths for the Panel or individual overrides so it’s fine for now
