Is there a possibility to adjust the column width in a table panel? I have 4 columns which should all have the same width (25%). Unfortunately they all have a different size.
No there is no option for this currently.
any updates on that?
Any update on that? It’s 2020, setting width in pixels only for various display types w/ different DPI is silly nowadays %(
Really, there is no option? Feels hard to believe that…
Seems it will be supported in v7.6 (see Table field options | Grafana Labs)
i still dont see the option for % width. is there an update on it ?
As a temporary work around you might want to look at dynamic text plugin where you have more control
for the love of god, allow to specify column width per column (or auto compute width per column based on longest entry)
