[Bug] Override relative time
If you select a time range with the mouse in a panel (meanings “from” and “to” are set with absolute timestamps), then all panels are overrided by this time range, even those set in their panel’s time range tab with a “Override relative time” like “Last 4 hour”, which should not happen.
Is not a bug, is a feature.
It doesn’t make sense for me. If I specify an override time in a panel, this is to avoid the main timeframe selected by the user.
Are you sure about that? Is this documented somewhere?
Yes!
http://docs.grafana.org/reference/timerange/#time-range-controls
