Bar Graphs Dashboard
Hi. Is it possible to create in Grafana the following charts listed below?
  1. Floating bar chart
  2. Bar chart with horizontal line
  3. Bar chart with horizontal reference line on each bar
If yes, can you please explain on how to do it? or give me some tutorial reference? Thank you.
is the horizontal line in 2 a metric or a static threshold?
looks similar to this one? @anon70503803
I am facing exactly the same problem. Have you solved this problem?
