Hi. I’m using Infinity plugin- JSON file as a data source. My data is a non timeseries value. Is it possible to have bar graph with a horizontal line on it? Like the attached image below
I can’t find anything how to do it.
Hey @diazstephanie .
This is actually a Community plugin, therefore best will be ask them directly.
On the main page Infinity plugin for Grafana | Grafana Labs
If you scroll down to the left side, you see how to contact them e.g. via Github or see their help section and can ask there, if the plugin can support what you want to achieve.
