I’m having problems with being unable to find a way to reveal the whole descriptions of my bar gauge fields since the names are pretty long yet I’d rather have the full name visible than the bar gauge taking most of the space to the right of the description fields. I don’t see a slide that would allow me to position the bars the way I want them. How can this be controlled?
Hi @yaro137,
Thanks for opening this post.
Can you please share a screenshot so that we can view and understand the problem better?
@usman.ahmad, I think I’m having the same or similar issue as @yaro137. I can’t figure out how to allow for more space for field names…and event values have tons of padding. Can any of this be configured?
Thanks @cjs226 for the screenshot.
Yes, I understand it now better. But unfortunately, I do not find any option which adds some padding/spacing between each bar value.
We would appreciate it if you can open a bug report about this in our official GitHub repository using this link.
Provide all the information (you can simply copy/paste your data + screenshot from here to there).
Lastly, paste the link to your GitHub issue here in this post so that all other community users can also track it. I will also add more additional information to it ![]()
