How to fix cropped labels?
Quick question, how do I get the full name of the values instead of cropped “VALUE…” ?
Here it is my current challenge, as you can see some server names are showing up correctly, while others for having a few extra characters are shown as “SERVER-0…”
My query just shows the server name, available disk space, and its total disk size, nothing more but some servers are shown with the “…” - and I can’t find anywhere an option to define the length or width for the bar gauge panel, is there anything to fix this issue?
Did you find a solution for this?.. It’s crazy. My labels are all 5 characters long and some are cropped…
You could try changing the placement of the series name:
if you’re also using Gauge Bar with Horizontal orientation, but it also isn’t ideal.
??? That doesn’t make any sense. If you have horizontal orientation, labels should be either left or right, top doesn’t make sense. And if you actually select Orientation=Horizontal and Placement=Top, the labels are not even displayed.
Well, it works in supermarkets where price tags are below or above the shells :smile: It would look like this, which, IMO, does look ok
Depending on the number of series, it might not display, you’d need to expand your panel in height.
As I said before, it isn’t ideal, but I don’t think there’s any other way. You can always try to expand your panel in width if you have to have it on the left side. Unfortunatelly, I don’t see any option to change size of the labels, you’re always welcome to make an issue on Github :smile:
Well, that’s not my experience. I mean, my labels are not even long. They are all 5 characters long and they don’t fit. No matter how wide the panel is on my ultra-wide monitor…
I have the same issue. As in empz’s case, my labels are quite short; they are just 3-digit signed numbers. I padded them with spaces so they would sort correctly, so they are all four characters long including the sign. e.g.:
@empz or @mrdrsushi have you found any solution or workaround to this?
