9.3.2 -
Create horizontal barchart with long y-axis lables -
Using bar chart visual -
What happened?
Long y-axis labels are cut on left side, means the beginning of the labels text is cut.
This happens with 100% zoom of brower (chrome). If I zoom out to 67% I fully can read all labels. But 67% is too small -
I expect that the lables appear fully readable without beeing cut on left side. -
no -
No errors in grafana UI. -
I could not find any instructiosn regarding this issue
In the example the bottom label text and the 3rd one from bottom are cut:
How could I configure the barchart properly to make the labels text fully readable without beeing cut?
