Hi, can someone explain how can i rotate labels on the bottom? My labels are long. I’m using Bar Chart.
welcome to the
forum, @paulohnunesx
in newer versions of Grafana you can use the “Roatate bar labels” feature in the panel editor:
I use Grafana V9.4.7 - bar Chart
It would be very nice if you could tell me how to display the bar values above the bars?
