Hi @seqway - The upgrade documentation includes recommendations for backing up your database which would be the same steps you’d want to take before migrating: Upgrade Grafana | Grafana documentation
This user posted a recommended step-by-step on migrations for self-hosters:
Maybe it would be a good idea to use a mariadb to store the configuration, dashboards … instead of a local grafana.db file. You can use a db on a separate host and connect to it from any other host or container with grafana installed.
