How to migrate database to another new VM
How to migrate the database to a new vm. I can’t find how to get the database, even for backup!
Welcome @anno
What version of grafana and on what os.
v9.5.1 ubuntu 20.04
v9.5.1 ubuntu 20.04
What does your ini file say as to the location of your database?
Probably db is located at
var/lib/grafana
If the database is grafnana.db than i got it, but i don’t know. It is really stupid!!! that there is no way within the webinterface to simple backup all the data.
Check the. Ini file it will tell you for sure
