Azure SSO Authentication without Client Secret
Is it possible to use Entra ID for SSO authentication without using a client secret.
Below link explains how to create/enable auth.azuread is grafana config
Is it possible to use certificates instead of Client secret in grafana.
Yes, use PKCE, so you don’t need any client secret or cert.
I see that even with PKCE we need client secret.
PKCE for OAuth 2.0
Where do you see that?
That means using PKCE I can go ahead with client authentication Method as None.
Also PKCE needs to be enabled during the Entra configuration right to Allow public client flows.
