How to use Client Certificate to enable Oauth for Grafana
I am trying to configure oauth in my oss grafana ,i dont have ablility to use client secret for authentication.
With that said how to use client certificate /Client assertion mode to make authentication work
  • What happened?
bump, is there any update for certificate based authentication using oauth? When I provide tls_client_cert, tls_client_key, tls_client_ca, it gives me back the error:
oauth2: \"invalid_client\" \"AADSTS7000218: The request body must contain the following parameter: 'client_assertion' or 'client_secret'
which leads me to believe it still wants me to pass in a secret even though I am trying to use a certificate
