Grafana version: v9.0.4 (c25601297)
OS: Linux (ubuntu 20.04) -
I am trying to authenticate sign ins through Azure B2C by configuring Grafana’s [auth.generic_oauth]. -
By configuring [auth.generic_oauth] in grafana.ini -
What happened?
I am receiving the following error:
After reviewing the logs, the problem appears to be I am not receiving the access_token from Azure B2C -
To complete the sign-in successfully. -
name = AzureAD
icon = signin
enabled = true
client_id = <redacted>
client_secret = <redacted>
scopes = https://graph.microsoft.com/openid https://graph.microsoft.com/offline_access
auth_url = https://<redacted>/nupaSystem.onmicrosoft.com/<redacted>/oauth2/v2.0/authorize
token_url = https://<redacted>/nupaSystem.onmicrosoft.com/<redacted>/oauth2/v2.0/token
email_attribute_path = emails[0]
allow_sign_up = true
;tls_skip_verify_insecure = true
[server]
# Protocol (http, https, h2, socket)
domain = <redacted domain>:<redacted port number>
root_url = https://<redacted domain>:<redacted port number>
protocol = https
Its worth noting that I am using a self signed certificate for HTTPS, maybe this could be the source of the problem, since my grafana [server] configs and redirect URI in Azure configs use a fully qualified domain name.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
grafana log shows the following error:
level=error msg=login.OAuthLogin(NewTransportWithCode) error=“oauth2: server response missing access_token”
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=1 uname= t=2022-09-29T15:51:55.294116834Z
I have debug enabled for the log level, but I don’t see any relevant logs to point me to the source of the problem.
- Did you follow any online instructions? If so, what is the URL?
- Configure generic OAuth2 authentication | Grafana documentation
- https://community.grafana.com/t/trying-use-azure-ad-b2c-for-sso-using-generic-oauth-and-getting-vague-error-when-trying-to-troubleshoot/64516/2
- https://community.grafana.com/t/sso-using-azure-ad-b2c/23454/2
I appreciate any feedback, thanks!
