Grafana enterprise 11.5.2 on Windows Server 2016 data center
We are setting up Azure OAuth authentication (which is working) but we can’t seem to get the auto_login settings working correctly. When users hit Grafana we expect it to ask for authentication immediately but at the moment we get the login screen and we have to click ‘sign in with Azure AD’
Set auto_login in the custom.ini file and turned off all other auto_login parameters from other forms of authentication. Azure OAuth is the only auth method in use. -
What happened?
Login screen keeps coming up
Instead of login screen, expect the microsoft auth page to come straight up as if you click the ‘sign in with Azure AD’ button -
#################################### Azure AD OAuth #######################
[auth.azuread]
name = Azure AD
enabled = true
allow_sign_up = true
auto_login = true
client_authentication = client_secret_post
client_id =
client_secret =
scopes = openid email profile
auth_url =
token_url =
allowed_domains =
allowed_groups =
allowed_organizations =
role_attribute_strict = false
allow_assign_grafana_admin = false
skip_org_role_sync = false
use_pkce = true
No
Yes - ensured only one instance of auto_login is set in the custom.ini
Any help would be greatly appreciated!
