- Grafana v11.5.1
Configure Azure AD/Entra ID OAuth authentication, if change to auth.google, auth,gitlab, auth.github etc then the SSO option will appear in the login page, only auth.azuread not showing. -
Configure in the Grafana Helm chart values.yaml -
What happened?
The SSO option does not show in the login page. -
The SSO option of Azure AD should appear -
grafana.ini:
auth.azuread:
enabled: true
allow_sign_up: true
auto_login: false
client_authentication: client_secret_post
client_id: “xxxxxx”
client_secret: “xxxxx”
allowed_organizations: “xxxxx”
auth_url: “xxx://login.microsoftonline.com/xxxx/oauth2/v2.0/authorize”
token_url: “xxx://login.microsoftonline.com/xxxxx/oauth2/v2.0/token”
scopes: “openid email profile”
role_attribute_strict: false
allow_assign_grafana_admin: false
skip_org_role_sync: false
use_pkce: true
role_attribute_path: “contains(roles[], ‘Admin’) && ‘Admin’ || contains(roles[], ‘Editor’) && ‘Editor’ || ‘Viewer’” -
No errors -
Configure Azure AD/Entra ID OAuth authentication | Grafana documentation
Why false, when you want to enable it?
Sorry, typo. Although I set as True, it still not showing.
If I configure through the Grafana GUI, then it works. Then, I disabled it and try to configure via helm chart values.yaml.
any progress on this?
I do experience the same issue with latest grafana docker image.
neither config.ini nor docker env variables work (GF_AUTH_AZUREAD_ENABLED: true)
i can configure the variables (clientID, secret, tenant, etc) from env variables, but can only enable through the UI.
“Env”: [
“GF_SECURITY_ADMIN_USER=admin”,
“GF_AUTH_AZUREAD_API_URL=https://graph.microsoft.com/v1.0/me”,
“GF_AUTH_AZUREAD_SCOPES=openid profile email”,
“GF_AUTH_AZUREAD_ENABLED=true”,
sign in with Microsoft is missing from the bottom
