I used Azure Monitor to access Azure Log Analytics.
On Grafana 7.0.6, Grafana could create a time-series from the returned data.
Now I upgraded to 7.2.2 and I get the message: “could not convert frame to time series, returning raw table”.
How to reproduce:
Query an IoT hub with Grafana 7.0.6
AzureDiagnostics
| where $__timeFilter(TimeGenerated)
| where ResourceProvider == "MICROSOFT.DEVICES" and ResourceType == "IOTHUBS"
| where Category == "Connections" and (OperationName == "deviceConnect" or OperationName == "deviceDisconnect")
| extend DeviceId = tostring(parse_json(properties_s).deviceId)
| project metric = DeviceId, state = iff(OperationName == "deviceConnect", 1, 0), TimeGenerated
| order by metric asc, TimeGenerated
Sadly I do not know the exact kusto version.
On the Grafana side I am using the latest Grafana plugin of the main repository. Here the link to the one before integration: “Azure Monitor”.
On the Azure side I query against a Log Analytics Workspace pay-as-you-go.
Maybe a more straightforward question. How do I get this selection back?
In the Query Inspector (Version 7.0.6) It is called Transformer “None” and I can select results. Which are correctly translated into time serieses. As seen by Time (20).
The 7.2.2 version is doing something differently and no automatic transformation takes place. How do I enforce the old behaviour?
Another Screenshot from 7.0.6:
