I am just starting to work with Cloudwatch metrics and I downloaded some Dashboard to see the AWS cost,
In all value of cost metrics I see a difference
AWS Billing Dashboard show 600.00 instead of 60.00 on AWS cost console
and from AWS console
Maybe I have to add some “Expression”, but I dont have the knowledge to do it
What does the query look like for that metric? And has that dashboard made any adjustments to the unit or other elements in the Panel’s editor?
VJ1981
3
I am having same issue, Did you get any solution?
VJ1981
5
I am using this dashboard AWS Billing | Grafana Labs
VJ1981
7
First one from grafana and 2nd one from CW.
