Average of values when using different time range
    10.3.1
    Check a panel with a 7-days time range
    By changing the time range on the dashboard
  • What happened?
    The panel shows me values from every 10 minutes, resulting in missing values
    The panel shows an average of the last 10 min for each value.
I was wondering if there was something I can change except the Max Data Points parameter to not have missing values when having a higher time range. At a 7-days time range, the panel shows a point every 10 minutes, resulting in missing values like peaks that happened every 10 min + 1. I’d like the value shown on the panel be the average of every points since the last point shown (on the 7 days example, let the value shown be the average of the last 10 min). Is it possible ?
