I tried to auto provision Prometheus data source with access mode as Server.
config file version
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
access: Server
url: http://prometheus:9090
editable: true
In UI, the data source is created with access mode as “Server (default)” but I wasn’t able to “Save & test” it. I get the following error.
When I select the option “Server (default)” manually again , then the data source is saved properly and I am able to test and monitor it.
Is this is bug or is there something wrong with my config file?
Thanks
