Hi!
I have an alert rule which is linked to a timeseries panel, because I want any alerts to show the dotted lines/marker (similar to annotations) inside the chart.
The alert rule has a 30sec pending period before firing. Problem is, every time it switches to pending it creates a marker as well. Is there any way to hide those? I only want it to show when the alert rule actually fires.
^you can see in the image how noisy the pending markers get. Any pointers would be much appreciated.
Thanks!
