Hi, we search a way how to integrate Grafana in Android and iOS Apps. We want to display Grafana Dashboards in apps, without extra login (we want to login via API). We use Kotlin in Android, Swift in iOS.
Exists there an API what we can use for it?
This is not an official Grafana repo, but you can get inspired or use it in your case :
Hope it helps.
Good Luck
Thanks a lot. I found Graffy, but the last things where done 4 years ago. Additionaly it is written in react native. We cannot ingtegrate it in native apps.
